bucklesfriendly
- Jul 24, 2022
- 1
Electricians are so hard to find in rural maine!!
I have 12 q cell 340s already mounted to my roof. They're about 60 feet from the house sub panel. The Main panel is about another 40 feet away in the garage. I don't know why it was done like that; the CBs inside only run the garage and the house sub panel.
May I mount he inverter next to the sub panel? Running the wire from the sub panel to the main panel is beyond me; 2 crawl spaces and a concrete slab.
Should I use a combiner box?
May I hook the panels together when its light out, or would/could that lead to a shock?
When I run the wire from the panels to the inverter, or combiner box, may I run them next to each other? I worry they'll heat up in proximity and may cause a fire.
I won't hook up the inverter to the CB panel, but I WOULD like to mount it. Maybe the electrician will come out if they think its an easy job.
Thanks from the noob!
C
C
