paul.simon.eu
- Aug 14, 2021
- 6
Hello to all,
so an active balancer of the flying capacitor style (like the Heltec/Hankzor 5A modell) takes charge from the highest voltage cells and transfers it to those cells with lower voltage. I was wondering if anyone here has a rough estimate of the efficiency of this process? How much of the energy taken from one cell is actually ending up in another cell and how much is just dissipated as heat? Is it about 80% or even better? Or much worse? I really have no idea.
Background: My balancer is controlled by the programmable load output of my Victron MPPT solar charge controller. Absorption voltage is 14.2V for two hours and after that the controller switches to float at 13.5V (Victron recommended settings). At the moment the balancer gets activated as soon as the pack voltage exceeds 13.8V (3.45V per cell average) and is deactivated as soon as voltage falls below 13.75V (3.4375V average). After that my cells are all within 5 millivolts and I was wondering if I should enable the balancer a bit later and disable it sooner - even if I have to tolerate a few more millivolts of delta.
If balancing efficiency is really good, though, I would keep everything as it is (start balance @ 13.8, stop @ 13.75). Actually I am really happy with how the whole system in my van works right now - without the active balancer cells would drift just a bit too much over time.
Cheers
Paul
Cheers
Paul
