I want to do a capacity test on this battery. Charging it up as we speak. Should I let it run down completely till the tester shuts off or sooner at a certain voltage? Will the BMS protect it?
If you can keep an eye on this and see why it cuts out (one cell over voltage and others much lower is usually bad) it will help you manage you settings.
