Steve Dally
- May 10, 2021
- 32
Hey all,
A few months ago I posted about a build (2p4s, 560ah) that suddenly showed diminished capacity. You guys helped me by making me realize my cells were really out of balance. I finally got the chance to tear it down, top balance and build them back in to 2 separate 4s banks. I'm now trying to capacity test, but my new capacity tester shows very different info than my bms. While running the capacity test, the tester is showing 13 volts and 13.8 amps but my BMS is showing 13.2 volts and 16.2 amps. That's almost a 20% difference in wattage.... Do I just ignore the BMS info and trust the capacity tester?
(I'm using properly gaged wires, I've brushed and cleaned connections, etc.)
Thanks in advance for any thoughts or suggestions on this!
