OzSolar
Whatever you did, that's what you planned.
I'm getting ready to do a solar water pump at my place but would like to avoid the standard top of pole mount. I'll start off with two ~400 watt modules mounted on structure that I could eventually turn into a greenhouse for my wife.
Something like this ATV carport is catching my eye. I'd run some Iron Ridge rails across it and then use Iron Ridge hardware for mounting. I've already checked the engineering and to my pleasant surprise the rated PSF has plenty of room to add a solar array.
Curious if others have played around with this?
