Thank you, but Electrical Engineering college courses and 12 years working in this industry taught me better that some YouTube videos.
This forum is because of Will's "
some YouTube videos".
Did you even look at the videos I showed you? Or never saw an oscilloscope ?
Voltage is not passing from point A to point B, only current can pass thru circuit. Voltage difference only means current can flow if allowed.
When gate is open current flows into battery, raising it's voltage ONLY based on it's internal state of charge, regardless of what voltage is at the panel. SCC senses voltage at the output and should not allow it to go above preset value regardless of voltage at the panel. During the short time when PWM gate is open voltage at SCC drops instantly due to current flowing, drop is allowed by a lenght of cable between panel and SCC.
When PWM gate is open and current is flowing, voltages are different at all points in a circuit. Even saying that panel voltage goes to battery is a nonsense statement. Voltage doesn't go anywhere and it's different everywhere in a circuit at any moment of time.
Nope. Volt is potential difference. This difference causes the current to flow.
Higher V defeats more easily the resistance and raises current higher. I = U / R (A = V / Ohm)
That is why you need a CC-CV battery charger. On the bulk charge (CC) part you have to limit the V (like 3V per cell for empty LFP) to limit the charging current (like 20A).
So when you use a PWM charge controller (example 24V solar) to have 20A to flow and reduce the
average volt to 12V (half the solar) you have to close the circuit half the time. Like 10ms open, 10ms closed. So 20ms period. P = U x I ( W = V x A) , W = U x I x s ( Wh = V x A x h)
Only every second part will current flow so :
- 0V 0A (circuit open 10ms), then next
- 24V 40A (circuit closed 10ms) ... hammer time ? ? (or square root 2 * 12V and 20A ?)
to have an average of 12V 20A.
On the absorption part (CV) you have to limit the V to the max allowed (like 3,5 per cell = 14V)
- 24V 40A (circuit closed 14ms)
and the current will go down as the battery gets full and the resistance rises.
On the other hand the same CC part with an MPPT:
- 12V 20A constant. (+- some V and A)
The V and A values only examples, not exact values (and it is 4am).
