Hey all. New here, and keep coming across the forums when looking for info.
Basically, looking to set up a small simple battery set up for the car to power fridge while away camping. Not exactly made of money so trying to keep things on the lower cost side, and my needs are quite simple as I really only need to power the fridge for a few days. Charging at this stage is intended to just be the alternator while driving around between fishing spots etc.
Cost of DC to DC chargers that everyone recommends is around the same as I'm looking at for the battery itself. It all just starts to look too hard and expensive. Most other people in my situation seem to throw thousands at just powering a fridge. Paid $700 for the 4wd if that gives some context on my budget.
I'm not completely new to lithium type batteries, using them a fair bit in the past in the hobby type area, making up drill packs etc etc. Looking at something like a 40-50ah LiFePO4, may make the pack up myself but that's a different conversation.
I know constant current constant voltage is used commonly with bench power supplies to charge cells and packs. Finding a boost CC CV power supply to run on 12v dc is quite cheap, much much cheaper than DC DC charger and plenty of options in the amp size I'm looking for.
Is there a good reason why I can't just use one of these boost cc cv converters set to 14.6v and say 10a to charge while driving around?
My one concern is that they likely won't drop the current completely once battery is full and continue to pump in 200ma or so. I've been thinking about coming up with some way to either open a relay once current drops under a set amount, or just power a buzzer to alert me switch off the charger. Or is this not even a big issue and battery will absorb that?
Appreciate any advice you can offer
Cheers, Stu
Cheers, Stu
