So I built a 4 cell 280ah LifePo4 with the eve cells I got from dongguan lighting. While I still had a house, and electricity I had done the top balancing with a 10a charger. And I did it 3 days in a row until the cells rested at 3.5v. then I drained them to 3.3ish and packed them into the bus.
I moved a week later, and it took another 9 days to get the solar components hooked up. (Mppsolar 1012 aio, DGJBD bms, 600w panels.)
Now when it charges the cell #2 is peaking out faster than the other 3 at the end of the bulk cycle. By about .150 v.... they all settle back down after a bit of rest and are within .015 or so.
So is this a huge issue? Will it correct itself over time hopefully? Or is my only course of action to top balance again, which is going to be nearly impossible since I'm 100% off-grid.
Here are some screenshots.
View attachment 25197View attachment 25199
I have two banks of 16 cells parallel 280ah without a bms, but I did add an active balancer on each bank that I can monitor with my phone.
Since adding the balancer I've noticed that not all cells are equal in some form or another.
Capacity, resistance and chemical reactions within are not all the same for each cells.
All my cells are grade A, to a point, but not all cells are.
They vary in voltage while being charged, I've noticed up to .150v or 150mv, and my cells are balanced.
With that kind of fluctuations between cells, a bms would always be triggered.
I control charge bulk at 56.8 volts, and this one cell has reached 3.62v while the others are around 3.53v and some a bit lower.
And as soon that I apply a heavy load on the bank, that same cell is at the lowest of the bank.
I thought for sure I had a bad cell, so I contacted Amy at Xuba, and she replied back that they had heard of the same problem and the solution was to change the cell place with another.
So I did, I took cell number 16 and swap it with #1, and voilà no more problem. Now my cells are all the same within.005v most of the time and don't need to balance.
So maybe if you try to swap cells with another, would work out.
I've done this swap about 40 days ago and everything is still very good.
