Cell 8 and 9 not reading voltage on jk bms
MrPsychedelic
Maryland
I have 2 batteries with 2 jk bms. When I plug in my JK BMS the one works fine, the other battery doesn't read voltage on cell 8 and 9, but I get voltage on the clip when checked with a volt meter. Did I get a bad BMS?
You might want to check this: 'JK BMS Cell Count Problem on B2A24S20’
Link doesn’t appear to be working for the title thread above
If this is the inverter bms are you sure you don’t have the plugs swapped to the wrong spot?
Sounds like a connector issue. Make sure that the pins are snapped all of the way in.
I assume he is using the JK Inverter BMS hardware.....beware! There are two +8 pins. You must only plug either one of this +8 pin and not both.
