henk_lifepo4
- Oct 31, 2021
- 26
Hi
I have a Battery with four 220 Ah cells with a JBD 200A BMS. It worked fine for about four years. The cells were normaly within 10 mV.
Recently i saw on the App that one cell had no voltage any more. I took the Battety apart and measured the cells with an YR1035+ . The cell with zero voltage has a resistance .15 and 0v. The other three have a resistance off .15 to .17 and all 3.30v.
Now i am wondering. I had expected the faulty cell to have a verry high resistance but 15 mOhm look good?
I tried to load the faulty cell with 3.6v and 5A. But it does not hold any power. So I think it is gone.
I do not understand how this is possible as the BMS should have stopped the decharche at an undervoltage of 2.5 v? Is the BMS maybe also not ok?. There has not been a Temp lower then 13° celcius or much heat and also not a high draw of Amps.
I plan to buy one new cell to fix the battery. Can I just connect it to the other three cells to topbalance and then rebuild the battery? After that I can measure the capacity to also check the other cells.?
Kind regards,
Henk.
Kind regards,
Henk.
