TomC4306
Solar Obsessive
Raise your balance turn on voltage to 3.4. 3.3 is too low
to @Alexplose I'm going to say (having read the whole thing at least passingly) what I think you need to do is individually charge each cell and monitor current and take each cell to the 3.65V level and measure the input current (I use a tool like a 150A in line which reports to me the voltage and the amps and other details in summary). Do this for each cell. Then do a discharge test at something like C or half C and again document that. This will (imo)Simple answer, #13 is always lowest v on discharge and always first to reach cutoff when charging… the cell is lowest capacity.
this is a good theory and different BMS's have different capacity for a delta V between cells (especially passive type BMS).It's almost like the cell balancing process that the BMS may be attempting is corrupted. It tries to balance but pushes more volts than it should. Like it's pulling volts out of all the cells but two and sending that voltage to the two cells.
@Alexplose Just be very careful going the last .1 volts. there is very little AH left and you'll reach 3.65 a lot faster than you expect... I know i overcharged a few cells when i first put my pack together.If you "top balanced" your cells to 3.55 you didn't top balance you cells. Fully Top balance to 3.65 you won't hurt the cells if you're doing this properly.
The very first time you got your cells and you said you top balanced the was is 3.65 or 3.55?
Is this top balanced when the voltage accross the pack is 3.654V, and the individual cells are about 3.650-1V, charger is still pushing some amps, I disconnected, will let rest and see the resting voltage.
Yes that's it, so now I need to take them apart and see which one is mis behaving."I disconnected" - assuming you mean disconnected from the charger.
Once you terminate charging, you need to disconnect them from being in parallel. If you leave them in parallel, they will all stay at the same voltage. Disconnecting them will allow you to see any outlier behavior.
I measured 3.642, 3.643 on all cells how many time before I can see something ?
+1 day but i am not sold it is a cell that is the problem from reviewing your graphs & given a large number of cells are showing wide swings. my bet is a bad bms or bad bms setting or wire / connection issue.Yes that's it, so now I need to take them apart and see which one is mis behaving.
At this time the deviation is between 3.604 and 3.595, I'll let some more time to make sur, and will recrimp my bms wires
@Alexplose so these numbers look really good! Better than my pack when I put it together. evidence I believe that this points to a bms or settings issue vs. a cell issue.Here is the measured voltage this morning :
It seems that the cells that were the farthest from the charger legs, have the lowest voltage. (former #13 is the lowest, maybe the weakest)
- 3.583
- 3.577
- 3.584
- 3.584
- 3.588
- 3.585
- 3.576
- 3.575
- 3.574 (former #13)
- 3.575
- 3.586
- 3.581
- 3.586 (former #09)
- 3.588
- 3.581
- 3.585
Do I need to individually charge the lowest ?
I'll rebuild the pack when I have some time, I soldered the bms wires into the crimps to make sure connection is good.
@Alexplose great news. It has been my experience that at the high and low end of the charge / discharge curves the cells start to deviate. Since I keep my overall pack to a rough 20-80% range I avoid this scenario and do not have to rely on the BMS to do any balancing. For my cells that usually means cells above 3.45v and below 3v.Hi everyone,
I did put my pack back online a few days ago, here are the new curves I have.
Really impressive, I'll continue checking what it looks like on the high end and low end, to see if I have any issues, It seems that #3 has a connection issue, maybe a bit dirty. But so far I like what I see.
Thanks for your help
actually having spent my time on other chemistries (lithium, but no fepo4) I wonder how you can actually "balance" if you don't take them to 3.65.If you "top balanced" your cells to 3.55 you didn't top balance you cells. Fully Top balance to 3.65 you won't hurt the cells if you're doing this properly.
Basicallyy, how I understand things such as how a BMS works is that if you stop charging at 3.55 you won't get balance occurring because (as I understand it) balance to lagging cells is handed out when they get to 3.65V (and thus significantly drop their ability to absorb current). I understood that it is on measuring this current that "charge completion" was calculated inside the BMS.
For instance, while this diagram is for lithium ion (cobalt) I understood that aside from the actual voltages involved the rest of the curves are the same.
Can someone provide an explanation of how actual charge balance occurs if charge is shut off at 3.55 and why this will not result in cells drifting slowly out of balance with each discharge curve?
Thanks
