frthompson
- May 29, 2021
- 62
I have 2 12 volt batteries consisting of 4 eve 280 ah cells and a jbd bms in parallel and a victron multiplus charger. My cells seem to be behaving well and are very close in voltage. Balancing kicks in at 3.4 volts but cells are typically plus or minus 0.01 v. But at the very end of the bulk charge when switching to absorption one cell voltages diverge a little and one is going over the HVD which I have set at 3.65 v. My bulk absorb voltage is se a 14.3. Should I try dropping the bulk/absorb voltage? Float is set at 13.4. I did top balance prior to assembly and installation in my trailer--Frank
