Hello all! I'm new here but have been reading as much as I can of these posts lately and am hoping to jump in on making my own battery sometime soon-ish.
My plan: I plan to build my own battery and hook it up to a growatt 6kw off grid inverter (the one with the transformer) and set some circuits up on a continual ups, essentially. Initially I will not have solar connected, I will be doing this in phases as the money is available for each portion, and will use it for grid down type situations power a separate panel with some select circuits in my house. Eventually I plan to add solar to it and have some (and hopefully someday all) circuits powered by solar and battery then assisted by grid when needed.
On to the battery question. I found these prismatic cells on alibaba. I'm not sure of the truth behind the claims but I like the design with the covers that can cover the terminals on each end. Now I could be way off on my math, but when I calculate it out, needing 16 of them to make a 48v battery, it would cost $864 for 16 cells at $54 a piece. With the listing of 200ah that would give around 10kwh of power. That brings the price to $86.40 / kwh?? If it's true, this should be a great deal, but as we all might know, claims and real world tests don't match up with a lot of these listings and cells.
Just curious if anyone has any thoughts on these cells or if anyone has these cells? From Noah's Ark: Index they appear to match the styling and build of the GBS cells but maybe different as the listing is showing the positive terminal on top and the negative terminal on the bottom of the cell?
I'm not in the immediate purchase phase yet so I'm still planning and working things out, but if these are indeed legitimate cells that match their rated listing, I see them being one of my top contenders when the boss lady gives me the green light. Just looking for some discussion and thoughts on the cells listed. Thanks for any consideration!
