BigWhiteDOg
I'm about to start building the box for my battery and wondering what the pros and cons are of 3mm EVA foam vs 0.5mm epoxy sheet (I've got both on my workbench, so availability isn't a concern)
In my mind, the foam option gives the cells a little breathing room as the charge/discharge, but the extra thickness over the epoxy sheet means my 4 pole flexible bus bars no longer span the required distance, so I'd need to get some copper bar and make my own (which isn't the end of the world, and would also mean I can go thicker, but would take more money/time)
Should also mention, it's going in a caravan, so will be subject to a bit of movement if that makes a difference. Would the foam give a little too much over time and leave the cells rattling around?
