Rednecktek
Expert Newbie
2) split phase 240v genny may be a problem. Because of neutral, you may need to put each line into a separate mppt. Now you have 60v on average on each line. Most AIO need about 100+ min voltage. 120v genny would be the same problem. Let's say you clip the 100-120v range, is that bad for the genny?
The whole point of gong to DC and through the MPPT is to make the 120v/240v a non issue. The minimum voltage may be an issue though. These high voltage requirements can be a PITA at times. That's one of the reasons I use the AIO's that I use is they don't require hundreds of volts and long strings of panels to charge a 24v battery.
What's the minimum on the 6000xp?
