Change Seplos Mason connectors to 8mm?
Misant
NL
I want to change the external battery connectors of the Seplos Mason kit so i can use 8mm bolts and not have to use the special connectors.
Does anyone know a source to get replacements on which i can attach the powercables wth 8mm bolts?
Like the ones used here:
What are the specialized cable connectors needed if you were to use it stock as is?
Hi, Did you manage to get an M8 connection to your Seplos Mason kit ? I too don't like the look of the supplied connectors. I did manage to get these (see attached) but the pitch of the mounting holes does not match the Seplos panel hank bushes so not much help.
