Changing serial to parallel
Sensaciones
I found 4 second-hand AGM batteries (12V/250Ah/identical of same date in 7/2020). They were used for just 3 months in serial (48V system).
I plan to use them parallel (12V system). Any problem with that?
When connecting Lead like this, there is one very simple rule that applies, even if batteries themselves are identical, the weakest in the lot rules the roost ! Given the "Age" that should be no problem, BUT if they were abused, IE dropped below 50% DOD or pushed to limits they may have suffered some degradation... Lead / AGM is pretty tough over the short term, they can & do get a bit more finicky as they age up later... Really does depend on grade/quality & class of battery... IE Heavy Duty Deep-Cycle vs Motive Type or RV/Marine.
4x 12V/250Ah paralel connected, pay atention to use enough wire cross section depending on planned charge and discharge current and fuses.
