Trying to top balance my diy lifepo 24v 310Ahr battery bank. The cells are at about 3.3v as of now. I tried connecting them to a bench power supply in parallel but after a few days the amps are still at about 5.5a. It has been suggested to put 4 cells in series and charge with a regular charger and then finish them off with the power supply as above. I have a PowerMax 100 amp charger. My question is, is it safe to use this charger? The specs on these batteries indicate a continuous charge rate of 50 amps. This seems quite low for a 310ahr battery?
