You should use a charge controller of some kind to limit the maximum current and the maximum voltage. All lithium type cells should be charged in a CC CV mode. Constant Current (CC) "bulk charge" until the maximum voltage is reached, then hold Constant Voltage (CV) with the current tapering off to get full capacity in the cells, also called "absorption charge" stage. Absorb charge is not required, but will push another 10% of energy into the cells. LiFePo4 cells should typically not charge faster than 1C or current equal to the amp hour rating. Some can take a bit more, but check the data sheets. And the Absorption voltage is typically 3.65 volts per cell. So a 12 volt pack is normally 4 cells in series which comes out to 14.6 volts.
