Hoop33
I have an off-grid pole barn. Here's a picture of my setup. Everything is working great except when the battery gets to 100% charged. When I get to 100% the inverter goes into protect mode. This has happened twice. Both times I turned off the PV breaker to stop the system from charging. Also, I noticed the charge controller had an "E2" error code. "Battery Over-Voltage". I have setup the parameters based on the charge controller and battery specs. Do you know why the system is kicking out when the system reaches 100%? For now I am cutting off the PV breaker when I am not there to monitor the system. Thank you! Any advise will be much appreciated.
