JosephBr108
- Apr 11, 2020
- 15
Hi everyone!
Here's a brief layout of my RV solar system. I've also attached a picture of my wiring diagram. It's not perfect, but it is an accurate reflection of where I'm at so far.
A basic overview:
You can also see in the wiring diagram that I have listed a charge controller on the positive line in between the alternator and the positive bus bar. I think the RV already has a charge controller going from the alternator to the battery that the alternator has charged historically, but I still need to verify. If I do need to place my own charge controller in between the alternator and the positive bus bar, do I need to place another one seperate from the converter to battery bank OR can I run both positive wires from the converter AND the alternator through the SAME (all in one) charger controller?
SIDE NOTE:
In addition (not my primary question for this post), given this set up what type of converter do you recommend for plugging into the grid and connecting to the listed generator.
Also, what type of inverter do you guys most recommend? I'm looking for at least a 2000 watt capacity inverter. I am trying to save money and I came across this one sold by harbor freight (https://www.harborfreight.com/2000-...-modified-sine-wave-power-inverter-63429.html). Its super cheap.
Thank you very much for any and all assistance!
Joseph B.
A basic overview:
- (4x) 375 watt solar panel array (total: 1,500 watt array)
- 100 amp victron solar charge controller
- 8x 3V 280AH batteries (wired in groups of four, making two 280AH 12V batteries to make a total 560AH 12V battery bank)
- The RV is equipped with an Onan 4000 GenSet. Model #4BGEFA26100H / 120 AC / 33.3 Amps / Ph 1 / PF 1 / Hz 60 / kW 4 / RPM 1800 / Bat 12V
- RV also has an alternator (type not sure at the moment)
SIDE NOTE:
Joseph B.
