Experience level: Total electronics illiterate newbie
System:
Issues:
System:
- 130W Folding Solar Panel (2x 65W) with 12v/10A Charge Controller ZM9177 (https://www.soanar.com/store/category/344/product/zm9177.aspx)
- An older 12v N70ZZ Sealed Expanded Calcium MF Battery 600 CCA
- Smartphone with USB charging cable
- 12v 48W cooler
- Solar panels are preconnected to the PV terminal of the CC
- Battery connects to the battery terminal of the CC with prewired cable with alligator clips
- Smartphone plugs into the USB charging port on CC
- Cooler connects directly to battery with cable with alligator clips
Issues:
- When I arrived at the campground I setup the panels in full mid-summer sunlight. I connected the battery to the panels and the cooler to the battery. Everything seemed to be working fine, but by sunset (4-5 hours later), the battery was completely discharged. The next morning I setup the panels in full sunlight, but the CC seemed completely dead: none of the LEDs lit up, neither before nor after connecting the discharged battery, and nothing happened when I plugged in the USB cable to charge my phone. After packing up the panels I did some googling and read that the CC could be reset by leaving the solar panels covered and first connecting a charged battery before exposing the panels to sunlight. So, I charged the battery with my car using jumper leads while the engine was running. Sure enough, after connecting the charged battery the CC came back to life.
- The CC is supposedly capable of charging 12v devices like smartphones via it's USB port, without a storage battery being connected, but it only seems to do so sporadically. Only on a couple of occasions has my phone indicated that it was charging when connected to the CCs USB port, and even then it would stop charging within a minute or so.
- What's the point of a solar charging system that only works if the connected storage battery is already charged?
- If a storage battery should always be connected to a CC prior to connecting the solar panels, why would a portable system like this come with the panels prewired to the CC, knowing that the battery will regularly be connected and disconnected every time the system is relocated and stored away?
- Any ideas why the USB port would only work sporadically and temporarily?
