Hello All,
I have some deep cycle 12V batteries and a 1000 watt inverter for camping. They work great, and I got a great deal on some solar panels, but I can't identify a good charge controller for the panels I ended up with. I am adding the specs below, my meter readings report the panels are good and within spec, and I only want to use one panel at a time, any help would be awesome, thanks in advance ....
Sharp ND-N2ECUF
Maximum Power (Pmax)* 142 W
Tolerance +10%/-5%
Type of Cell Polycrystalline silicon
Cell Configuration 42 in series
Open Circuit Voltage (Voc) 25.24 V
Maximum Power Voltage (Vpm) 19.92 V
Short Circuit Current (Isc) 7.84 A
Maximum Power Current (Ipm) 7.13 A
Module Efficiency (%) 12.31%
Maximum System (DC) Voltage 600 V
Series Fuse Rating 15 A
NOCT 47.5°C
Temperature Coefficient (Pmax) -0.485%/°C
Temperature Coefficient (Voc) -0.36%/°C
Temperature Coefficient (lsc) 0.053%/°C
*Measured at (STC) Standard Test Conditions: 25°C, 1 kW/m2, AM 1.5
Sharp ND-N2ECUF
Tolerance +10%/-5%
NOCT 47.5°C
