Charge Controller Settings
MaryMark
Hi all,
Just need some advise re: settings for my solar charge controller.
Setup is:
4x LiFePo4 batteries - 12v configuration
1x https://overkillsolar.com/product/bms-120a-4s-lifepo4
Charge Controller EPSOLAR Tracer BN series controller - (Currently used for AGM batteries) where I can set:
Ah Capacity BMS
Equalize Time
Boost Time
Low Voltage Disconnect - BMS
Discharge Limit - BMS
Boost Reconnect - BMS
Low Voltage Reconnect - BMS
Under Voltage Reconnect - BMS
Under Voltage WarnOver Volatge Reconect - BMS
Equalize Charge Voltage - ??
Boost Charge Voltage - ??
Float Charge Voltage - ??
Charge Limit Voltage - ??
Over Voltage Disconnect. - ??/BMS
I figure the BMS will take care of most (all) of these - but I want to make sure I'm not missing something and that I configure the controllers correctly.
Many Thanks
Mark
Think I found the answers to these questions:
Under "Charging an LFP Battery" section
