I have a split phase 24v 6000w sungold power inverter. (6) HQST 200w mono solar panels (3)s (2)p. I checked the panels and there output is fine on each panel. I have (4) weize 12v 200ah lifepo4 all new and were fully charged before installed. The batteries are made into a 24v 400ah system. You can see pictured my aims 60amp charge controller and my user charge settings. Also pictured is what the inverter c.c.c. dial is set to. This system runs a 1/2 hp jet pump that fills my water storage pressure tank for house pressure all in perfect working condition and a 3/4 hp motor to fill my well storage tank that the jet pump draws from which also works fine. I live alone, so these units dont run much so my inverter really isnt working too often. My problem is that my inverter keeps shutting off at full charge and especially on really sunny days. It doesn't take long to shut off either. I thought maybe because it was idle for so long it shut off but it happens very quickly on a sunny day. I was wondering if my settings were to blame.
