fredrikfriis
I currently have two vestwoods VE48100E 5,12kwh batteries connected to a Deye 12k hybrid inverter with RS485. Each battery current is max 100A. The two batteries are monted in an enclosure with a 125A fuse. The inverter is set to charge/discharge at max 100A, but it is capable of max 240A.
I'm thinking of increasing storage to 20kwh with two more batteries. With four batteries capable of 100A each, 240 amps should not be an issue. (Assuming properly sized cables)
*But*
[1]
My batteries have a push connector, not thread/nut, so i have to use the included cables. I can't find if the "passthrough" current is higher than 100 amps. Will ask Vestwoods. Any thoughts?
Alternatively I can run a new set of 70mm² wires from the inverter to a busbar in the enclosure, and use the included 25mm² wires from there to the batteries.
[2]
Is the battery-inverter communication clever enough to split the requested current evenly between the batteries, when the total requested current is above the max of each of the batteries?
[3]
If a battery were to unexpectedly trip out, will the remaining batteries pick up the load and carry on with an error message, or will the whole system trip offline immediately?
*But*
[1]
[2]
[3]
