shanemgrey
- May 17, 2020
- 24
I am building a 48 volt battery with 560ah and would like to keep the power to the house clean and stable all the time.
But there currently isn't enough solar to keep up with demand if we have a few days of rain. So we use a natural gas powered generator. This generator works fine for most loads in the house when it's passed through. But some things like the microwave don't like it. And it's probably not great for other things even if they stay running.
I'd like to avoid running the house on the generator, and keep it fed from the inverters 24/7 instead. But I can't use the inverters to charge the batteries while also providing power. They have to pass the generator power through so they can switch to charge mode.
What would I need to purchase so I can use the generator to charge the batteries without involving the existing inverters?
The generator produces 7000 watt max continuous with a 30amp 240 volt split phase output as well as a couple 20amp 120 volt. Ideally I could run it at about 5000 watts over the 30amp connection. But it seems very hard to find any chargers that can take split phase power.
Can anyone point me to what I would need to make this happen? Or reasons I should do something else?
