blueshoe
- Nov 6, 2020
- 4
I could use some advice evaluating options for charging backup batteries (in the house) from the car (on the nearby driveway). The car, as the (trip-hazard) cable runs, is about 20 feet from the kitchen (the closest enclosed space in the house), or about 60 feet from the basement (by the service panel).
The basic idea would be to have enough battery back-up (plus a healthy reserve) in the basement to power the house's critical loads through the night. If power loss is prolonged, use the car as needed during the day to re-charge / top off the batteries (and, potentially, simultaneously power daytime critical loads).
(Long term plan is to DIY solar panels on the house; tie to the grid; buy an electric car; convert gas appliances to electric; then finally to retire to a mountain or an island somewhere and start this all over again. But first thing's first, and that's having a good power backup plan for this winter.)
So, there's plenty of advice out there on charging accessory batteries from car alternators. But what I've found looks to be geared for permanent installations which have a good location for power equipment that is located not too far from the inverter and the batteries. I'm not sure how well it applies to my desire for temporary use, without a great location for placing the equipment, located a sizable distance (for 12VDC) from the alternator.
I'm looking for to do something based on the following requirements / priorities:
Here's some options I've been considering. I'd appreciate some feedback!
Some of those options could be tweaked by locating some of the components in the kitchen (20 feet from the car) instead of the basement (60 feet from the car).
Any thoughts? Thanks!
- Safety first!
- Don't shock people or small animals
- Don't explode or start fires
- Don't damage the car
- (The risk of accidentally draining the car's starter battery would be great to design around, but is potentially acceptable.)
- (I can accept the trip hazards.)
- Minimum modifications to the car
- Preferably none!
- (I don't necessarily know in advance what, or whose, car I'd be using this with, for one thing.)
- Can be used during bad weather (meaning snow and rain, not meaning during-a-hurricane or if the driveway is flooded)
- Tolerates a significant distance between alternator and batteries
- (My own application is for 60 feet, but potentially apartment-dwellers and such might want 150 feet or more?)
- Reliable enough to be comfortable believing it will work when I need it
- Cheap enough to justify implementing even when living in a location where power outages are rare and brief
Approach | Details | Disadvantages | Advantages |
In-car charging | Ferry batteries back and forth between the basement and the car; charge them inside the car. |
Direct DC | Connect DC cables "directly" (with circuit-breaker / fusing but not much else) from the car all the way out to the batteries in the house. |
AC inverter | Connect an AC inverter close to the car. Either put it in a weatherproof box / tent, or put the inverter in the car. Run AC into the house and use an AC->DC charger on the batteries in the house. |
12VDC charger | Run 12VDC cables (with circuit-breaker / fusing but not much else) from the car to the house, but use an appropriate DC -> DC charger to charge the batteries. (This would be a charger designed for alternator-based charging, targeting RV / marine / etc. usage.) |
DC boost | Use a DC-DC converter in / near the car to boost the 12VDC to ?VDC, run ?VDC to the house, use a DC -> DC charger to charge the batteries. (Possibly a solar designed for solar-based charging?) |
