Hi there,
I have just godt my New Pylontech US5000 home and when I measure the voltage with multimeter it says 49.3v which probably is normal when getting it after the transportation from company.
My question is:
Can I connect it to my Growatt SPF 5000 ES right away or should I charge it up a little to begin with.
If I should charge it first, can I then use this charger (attached)?
The inverter is also connected to 230 AC grid if this should matter.
Thanks
My question is:
Thanks
