Charge voltage
Norm01
Hi all, finishing up my 4S battery pack for my RV. It’s made up of CATL 302A grade A cells and a Daly 250A smart BMS. Data sheet on these says maximum charge voltage is 3.65v, I was going to limit to 3.6v however I see on many YouTube videos people limiting to 3.5v. What is the general consensus to prolong battery life and get nearly 100% SOC.
My top balancing was done at 3.6v In parallel. I went to series and applied a load and am down to +/- 3.3 now. So if I read you correctly you would,set the BMS charge voltage to 3.5V and 14v total for daily operation. Thanks.
It's normal the batteries drop down, let them sit a couple days' in parallel, then series.
I think your missing my question, should I set my BMS to charge to 3.5 or 3.6 now that they’re is series and BMS hooked up.
You don't set your BMS to control charging. The BMS is set to the safety limits of the cells/battery (2.5V to 3.65V or narrower by a bit).
You set the charge controller to control the charging (get it? its a charge controller).
Here is a voltage vs SOC chart so you can see where you want to charge. Hint: 3.65V is the theoretical limit of the cells before they are destroyed, its NOT really where they are meant to be charged everyday.
