I have a simple 12v 60a LIFEPO4 (4 fortune batts) and an overkill solar bms. I also have a Victron Blue Smart charger (12v/15a) to charge up the battery pack.
I would expect to attach the + and - from the charger directly to the 'final' + and - of the battery. The BMS (120a 4s overkill solar) is attached to the 'final' + per drawings.
This means the Victron charger is responsible for properly charging the battery and not the BMS (connected to a generator). (4 modes include Li-ion, recondition, High (14.7v) & Normal (14.4v) > In this case the BMS is watching the cells and max amps out (batt is 2C so tops out at 120).
Question: do I have this right, or is there some other way to wire this?
PS: Victron 800w inverter is being used - so don't expect to hit 120a.
