I just purchased 4 280Ah LiFePO4 cells. I'm trying to top balance them by the method favored by this forum. I have a Volteq HY3030EX power supply that I'm using to charge/balance the batteries. A year or two ago, I lent the power supply to someone who ignored my warnings about what not to do with it and broke the current limiting function of the power supply so now it only limits itself to its max rated output of 30A. The 4 cells all arrived at 3.200V +/- 10mV. I made buss bars using 1"x1/8" aluminum strap that I had in the scrap bin to put all 4 cells in parallel. I set the charger to output 3.400V measured by my Fluke 87V multimeter.
The results are... weird. I have previous experience with commercially made LiFePO4 batteries but not individual cells. In bringing those commercially made batteries (Battleborn and SOK) to 100% SoC before assembling them into banks, each battery sucked up the max current the charger could output before dropping to 0 current very abruptly when they were full. There was no slowly tapering current like you'd see with a FLA battery. These cells, when hooked to the charger, only drew 14.5 amps. Even weirder, current in would sag slightly when the cooling fan in the power supply turned on and rebound slightly when it turned off (this is the part that makes me consider a power supply problem). After about 5 hours of charging, the current into the cells has dropped to 4.5A. It appears to be exhibiting a long, slow tapering off of current like a FLA battery (which is what makes me consider a cell problem).
Any ideas to help me sort out what isn't working as expected?
