When an inverter first powers up, the capacitors in it are empty. Before it can start inversion the capacitors have to be charged up and that inrush surge can be very high and many BMS' will trip. The Battery Bank voltage is irrelevant. Capacitors can take a Low Amp input to precharge and that is what the precharge circuit does, it provides enough voltage out & enough amp "space" to charge the capacitors and avoid the inrush demand.
Look at the Chargery Manual, you will see who the editor was.
Jason / Chargery is one of the RARE Manufacturers who listens & hears client suggestions & ideas and works to implement them if reasonable. The DCC is one such example, they only sold those Electro-Mechanical PIG Relays and when Craig & I started testing different Contactors & Relays and SSR's (including commissioning new designs to support 500A & 1000, all the while with us being in contact with Jason, we convinced him that it would be prudent to make a DCC to suit ESS uses. The P series BMS' are Based off our Input & suggestions which is more focused towards ESS usage and bigger capacity systems.
The Chargery BMS' were originally designed for LEV (Light Electric Vehicles) NOT for ESS use.
Ironically, people who Harped on Chargery Issues went off and bought other BMS' like Batrium & Others which ALSO suffer similar issues and they are talking about that in separate threads. I read it, and wonder why they have not figured out that Many BMS' have similar issues.
Now, I have to add this here. One common thing that happens and some refuse to understand. The battery Cabling MUST be kept together to prevent ripple and magnetic fields (DC does this, higher voltage, worse it gets). This has a DIRECT Impact on BMS' and their voltage sensing / monitoring.
FROM SAMLEX (I won't bother re-writing this, as it says it all.)
1.3.4 Electro-Magnetic Interference (EMI) and FCC Compliance These inverters contain internal switching devices that generate conducted and radiated electromagnetic interference (EMI). The EMI is unintentional and cannot be entirely eliminated. The magnitude of EMI is, however, limited by circuit design to acceptable levels as per limits laid down in North American FCC Standard FCC Part 15(B), Class A. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a residential environment. These inverters can conduct and radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. The effects of EMI will also depend upon a number of factors external to the inverter like proximity of the inverter to the EMI receptors, types and quality of connecting wires and cables etc. EMI due to factors external to the inverter may be reduced as follows:
• Ensure that the inverter is firmly grounded to the Ground System of the building or the vehicle.
• Locate the inverter as far away from the EMI receptors like radio, audio and video devices as possible.
• Keep the DC side wires between the battery and the inverter as short as possible.
• Do NOT keep the battery wires far apart. Keep them taped together to reduce their inductance and induced voltages. This reduces ripple in the battery wires and improves performance and efficiency.
• Shield the DC side wires with metal sheathing / copper foil / braiding.
• Use coaxial shielded cable for all antenna inputs (instead of 300 ohm twin leads).
• Use high quality shielded cables to attach audio and video devices to one another.
• Limit operation of other high power loads when operating audio / video equipment.
Considering, when I am all done (Last 280AH pack underway), I will have 1,190AH / 30.464 kWh as my LFP bank. It is a significant investment and I am certainly not about to screw around and do a half assed job of it, especially because I am 100% offgrid, very remote and dependent on my systems. I won't install any craptastic stuff as a result. If I can do it, I will replace all of my BMS8T's with BMS8-P's which will also allow me to yank out the QNBBM-8S Active Balancers and that is a fair sized chunk of change BTW.
