peteappleyard
- Jul 2, 2020
- 7
Hello, I'm wondering if some of you knowledgeable folk can help me out...
I've tried searching the forums but can't find anyone else who's had this issue, so apologies if I've missed an answer.
So I've recently bought the Chargery BMS after reading recommendations on the forum. I'm using 4x 280Ah EVE cells to create a 12v battery. I'm using the 300A shunt that came with the Chargery and 2 solid state relays (the 220v DC 600A ones here: https://www.aliexpress.com/item/4000136607816.html?spm=a2g0s.12269583.0.0.26b67126OfTKd8)
I set up the batteries, top balanced them, then installed the BMS (powered internally from the cells, rather than external power) and shunt etc. Discharging works fine and I powered my inverter for ages and the BMS display showed a discharging current. My main issue now is that I've come to charge the batteries and the BMS isn't showing any charge going in to the batteries. The charger is definitely connected and working and the bms DOES show the individual cell voltages and overall battery voltage going up as the system charges. However, the display is stuck showing 22% state of charge and the Wh and Ah values are stuck too. I assume these values aren't changing because the shunt isn't detecting the charge going in to the battery?
I'm running BMS version v4.04 and I also have the issue as someone else did, of the unit displaying 0 for 'the internal R when cell in use'. I've tried cycling the power on the BMS. I haven't calibrated for the shunt as the Chargery says that if you use the supplied one, this isn't necessary. I followed Will's Youtube video to get it set up, and have ran through the instruction manual too, but I can't see that I'm doing anything wrong.
I've now stripped my system right back down to eliminate elements. My current temporary setup for testing is:
Charger neg > shunt > - Battery + < fuse < charger pos
As you can see, I've taken the relays out as well as any loads etc, still to no avail.
I'm really hoping that there's a setup step that I've missed or something, rather than it being a faulty unit. As I said, it worked with discharging perfectly.
Any help VERY much appreciated.
All the best,
Pete
All the best,
Pete
