Nigel Snook
- Nov 18, 2020
- 26
I have just assembled and tested 2 off 280Ah LiFePO4 batteries each with a BMS8T (V4.04), 300A DCC (Discharge) and 100A DCC (Charge) configured as separate port on the positive rails with ISO board in line. I am powering from the battery directly (no Schottky diode). I would appreciate some thoughts on my observations, particularly on the differences between 2 identical set ups:
1. At switch on, Battery A BMS reads between 0.5 and 0.7A discharge. At first I assumed this was the draw from the BMS, however spec is 133mA. Batt B however is a rock solid 0A.
2. Current Monitor - when charging, current readings spot on in both. Discharge however awful - at circa 100A, current reading between 60 - 160.
3. When discharging individual cell voltages on Battery A, the sample to sample (2Hz ish) cell delta varies significantly e.g. 5mv - 70mv with extreme cells changing each time. I am convinced that this is not real and each cell is discharging proportionately. Battery B is far steadier.
4. The 300A DCC voltage drop spec is 80mV @ 100A. I am seeing 170mV on both.
In summary - Battery B seems a little better than A. I have remade sample cables and there are no hot spots anywhere so pretty confident that all well with connections. Both batteries are assembled the same although they are a mirror image of each other for installation reasons.
Has anyone experienced anything similar or have any insight to offer?
