Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
It is really important to update to version 4.04 of the firmware, it fixes some math issues and the sampling calculations plus more.
The External power board makes a difference but you can make one with a shottky diode as mentioned above. That connected to the battery terminals does indeed help settle readings. The ISO board between the BMS & DCC also does a little filtering and having the LED's indicators is certainly a handy thing to have on had as well.
The SOC issue. It is a bit wonky till it's worked through a couple of discharge/charge cycles (this is not that unusual, most BMS' have to cycle a bit) and you have to enter the PROPER kWh for the pack and too many flubb that up.
kWh is calculated as so: using 24V/280AH pack as example.
- always use 3.200V - it is the Nominal Voltage
- Always use 4x3.2 for 12V, 8x3.2 for 24V, 16x3.2 for 48V. Cells in parallel do not count.
8 cells X 3.2V nominal voltage = 25.6V nominal pack voltage.
25.6V nominal pack voltage X 280AH (cell AH rating) = 7168kWh
ALSO the BMS has a setting for Low SOC Cutoff which has a default of 20%, reset that to 0% because the moment a cell reaches 20% SOC it will trigger a discharge cutoff regardless of the other cells SOC. This can cause the BMS to kick off too quickly if under load or taking a surge start from a motor like a fridge kicking on.
My BMS8T settings are located in the spoiler on this page:
My DIY off-grid Cabin setup in Ontario Canada (24vdc-120vac)
NOTICE: UPDATING November 2022 WIP Good Day everyone, Overview: There is no grid here, no phone lines, cell is so-so (to be polite) so satellite internet is here (not bad actually). I do not have 240VAC, this is a 120V system only. My Solar Panels are mounted separately from my Powerhouse...
diysolarforum.com
