geekdw
- Feb 11, 2021
- 4
Hi, I am new to the forum, and I'm also pretty new to solar and electricity in general, so go easy on me! A lot of this stuff is new to me and still confusing. So here's my question...
I'm building a Renogy solar charging station. 100w panel, 30a charge controller, 100ah Hybrid GEL battery, and 1000w inverter, all from Renogy. I think I've pretty much got all that in order, but I was wondering if I could use a 30a/12v power supply to charge the Hybrid GEL battery?
I've got the power supply, but I don't want to try charging the battery with it before I check with the community to make sure it will be okay to do that. If so, can I just clamp some 10awg wire to the battery from the power supply? Or do I need something in between them? I've seen Will put a fuse box in between power supplies and batteries, but it hasn't been to a GEL battery, and my particular power supply is 30a (that's the max charge current of the battery), and the power supply has over-voltage and over-current protection, and "surge protected outputs". So I'm assuming I can just run the power supply DC connection to the battery directly, but again I am new to this stuff.
Edit: Or should I run the cable from the power supply into the charge controller in the same ports that the solar panels go in?
