After dealing with my battery bank not being balanced I reconnected the wires with the help from this forum and per the wiring manual posted here. I chose the method of connecting the positive line to the first battery and the negative to the last battery in the bank.
I connected my inverter on the same batteries using the negative on the first battery and the positive on the last battery. Seems okay but wanted input to see if I use this method with the charging aspect is there a better way to do the inverter?
