Hi,
have 4 Eve 3.2V cells, 280 amp hours.
And an Overkill BMS
Over the winter battery pack went low, so am now charging the pack
I am charging with a 45 amp charger, the clamps being on the main positive and negative cable from the battery pack.
Do I have to constantly visually monitor the voltage of the cells via the app, or will the BMS shut the charging down to each cell when the cell target Volts is reached?
I would think the BMS could not stop the charge by this "pathway" but BMS could stop an over charge from my solar cells for instance..
Thanks for your input
And an Overkill BMS
