I pulled my RV out of the garage for the first time to test my new solar panel install. I have tested it to this point inside only through discharging and then recharging by a 50 amp shore connection.
Last night I ran some devices and pulled the battery bank down to 67% so today I could test the PV recharging. Shortly after pulling the camper outside the battery SOC went from 67% while in the garage to 100% within 3 minutes of being in the sun. No way this can be accurate...
I'm perplexed as to why this happened and what I can do to correct it. I'm using the Victron 500A Smart Shunt and Cerbo GX. Both MPPT controllers are Victron 150/45 and I'm running 2 arrays of 215w panels each for a total of 10 panels (5 in each array). I have 8- 12V SOC 100AH LifePo4 batteries in series at 24V .
Any suggestions or comments as to what is going on here are appreciated!
