I purchased:
1X EG4 6000XP OFF-Grid Inverter/8000W PV Iput/6000W Output/480V VOC IInput/48V 120/240V Split Phase/All-In-One
2X EG4-LifePower4 V2 Lithium Battery/48V 100AH/Server Rack Battery
I Wanted to install a 240V outlet. So I hired an electrician, who installed 1X 240V and 3X 120V outlets.
The electrician was knowledgeable in his job, but not so much on the solar power side.
I on the other hand, am not knowledgeable in solar. But I'm learning!
I live in an apartment and I'm looking to have a system set up in case the power goes out. We've had the power go out 5 to 6 separate times since we lived here 4 years ago.
The problem is is that the electrician set up both outlets, but it only charges on a 240V. Also, I had the system fully charged 3 days ago and looked at it last night and the system only had one bar of charging on the battery left.
If I leave the system unplugged from an outlet, is that normal to drain that quickly?
I tried reaching out to the electrician explaining to him that I can only charge it on 240V, and he could not answer the question.
When I attempt to charge it on a 120V outlet the system shuts off within 5 to 15 minutes. I've plugged it into multiple outlets within my apartment, as well as, putting a surge protector in between but it always shuts off. When it shuts off my apartment is not affected just the solar generator.
I welcome anyone's advice.
