Steve Dally
- May 10, 2021
- 16
Okay, I have a number of questions concerning the safety of charging my DIY 18650 battery packs.
1. for a 2s battery pack, 8.4 volts, 3000 mah (total of 2 cells), is it okay to charge it with a 'compact power adapter' that I found while cleaning out the basement. I think it went to a handheld camcorder that I threw out. On the back it says, "output 8.4 volts, 0.6 amps" so the voltage seems spot on, the amperage seems low at C/5. But it doesn't say, "Battery charger" anywhere on it. Is there something special in a charger, specifically, that's more than just providing 8.4 volts? (just for some background, the cells themselves are in good shape and I am using a BMS on the pack)
2. For a 3s pack, 12.6 volts, 3000 mah (total of 3 cells), how do I determine the proper amperage for a charger? does too big a charger 'push' too much juice into the batteries? Or does the battery 'pull' whatever is needed? In short, should the charger be on the big side or the small side, relative to the battery? I have an official, legit Lithium battery charger with an output of "12.6 volts, 1.5 amps). That seems appropriate for 3000 mah, but what would happen if I were to use my big 20 amp charger to charge this little pack? Does the battery blow up or does it simply 'pull' what it needs. Opposite scenario: What would happen if I were to try charging my 560 ah LiFePO4 batteries in my RV with the little 1.5 amp charger. Methinks the charger would melt down.... help?
Sorry for the newbie questions. Obviously, I'm quite new to this, but I'm learning a lot and really loving the process!
Thanks again for any and all help and suggestions,
Steve
Steve
