solarcamper
- Feb 25, 2021
- 1
Hi,
I'm looking for some information on how I should set up the charging parameters for my 40 amp Renogy Rover and my 12v BMW 3s Battery (Samsung NMC prismatic lithium ion cells) More info on the battery in this link.
I have a 3s Daly 100amp BMS
It says to set the charge controller to 12.6 for this battery but I haven't been able to find specifics on what I should set for:
Boost voltage
Boost return voltage
Under Voltage warning
Under Voltage recover
Low Voltage disconnect
Low Voltage reconnect
I am new to lithium batteries and to solar in general so any help is appreciated!
BMW OEM 3s 12v 75ah 869wh *Side Mount*
These particular 3s modules have the main connections on the sides as you can see in the photos. These 3s BMW batteries are PERFECT for 12v inverters. Check out the discharge curve in the 2nd photo and you will see that 95% of the energy is stored above 10v. Most 12v inverters cut off at 10v...
batteryhookup.com
Boost voltage
