Reef Whooligan
- Mar 14, 2022
- 18
I need some help understanding the parameters I should set on charger. The defaults for "AGM" don't look like they match my battery but thought I should ask before wrecking something. I have a MPP PIP-1012-LV and a Renogy 12V 200AH AGM.
The battery specs are:
The relevant looking settings I have available are:
- Bulk charging voltage (default 14.1v)
- Floating charging voltage (default 13.5v)
- Equalization voltage (default 14.6)
Is "bulk charging" and "cycle use" the same thing?
Float Charge Voltage (77°F/25℃) | 13.6V~13.8V; Temperature Compensation: -18mV/℃ |
Cycle Use Voltage (77°F/25℃) | 14.4V~14.8V; Temperature Compensation: -24mV/℃ |
Equalization Voltage (77°F/25℃) | 14.2V |
