I have an existing AGM battery bank (2x100AH) in my Sprinter/RV that I want to leave permanently. I replaced the combiner solenoid under the passenger seat with a CTEK Smartpass 120s and was also planning to add the CTEK D250SE. The Smartpass currently charges the AGM bank.
Now I am thinking about adding a secondary lithium bank given I can work remotely more and need a bit more power. But I want to have the option to remove it in the winter as my van is cold. I would just use this lithium bank for an inverter and the existing AGM batteries would take care of existing stuff (fridge, DC distribution, etc)
Could I just a run another DC to DC charger from the AGM battery bank in the back to the new Lithium bank? I realize I would have to run another alternator signal cable, but that's a lot easier than placing another DC to DC charger under the passenger seat and running new battery cables all the way back. It would also let me run solar to this DC to DC charger down the line. My concerns /questions:
1. Is it a bad idea to charge from AGM to Lithium? Having it only run with alternator signal cable help at all?
2. Is this bad on the alternator/existing CTEK Smartpass to add another DC to DC down the line?
3. Is there a better way I should be thinking about this?
Thanks-
Thanks-
