I have a similar question.
Looking for some help here from the very smart people in this forum.
I recently was givin some electric Razor scooters.
The stock batteries were dead so I bought some LIFePo batteries to replace the stock batteries. They were both 12vdc and both have battery built in BMS.
The question I have is charging.
I want to use the stock charging port on the bottom of the scooter to charge the batteries once they are in the scooter.
The new LiFePo batteries are 12 volt and they are in series to the speed controller. Unfortunately the charging cables once inside the scooter also go into the speed controller which makes me think there is some circuitry in the controller for the charging process. I am thinking of cutting the wires there and just running them to the batteries directly and using my RC charger to charge this thing.
My first question is. Since both batteries have a BMS, do I need to charge each of them separately before installing them and connecting then to the controller?
Where do I attach the leads from the charger to the batteries?
How do I determine how big the charging wires should be?
My second question is since I will be using my RC charger to charge these, do I charge them at 14.4 as recommended on each of the batteries? or since they are in series, I charge them at 28.8?
Please ask if yo need any clarity.
Thanks in advance.
