I have some solar panels and an LV-1012 MPPT. But for the extended weeks of cloud and overcast in the god-awful Canadian winter in my motorhome, I have ordered a K-Tor Power Box 50 so that I can generate some body heat while recharging my batteries with pedal power.
I am told that the Power Box 50 can be connected directly to my batteries for recharging them.
This is essential because I see that my LV-1012 has no connections for a DC input other than from the solar panels and unfortunately I will not be parked anywhere near where I could hook-up to an AC input.
So I really look forward to being able to keep my electrical requirements to an absolute minimum. And I can completely light up my desk with some full spectrum light from a 4ft 40w. single tube fluorescent fixture.
But I won't have any Internet connection so I will keep myself entertained by checking out all the building and fixing videos I have downloaded from Youtube with my 50 watt laptop.
So that just leaves keeping my batteries warm enough to be happy and hopefully keeping me warm enough too because I can cook on the wood stove that I have installed in my motorhome so that I don't have to be hiking out of the bush now and then just to backpack in some more propane for the stove & furnace. If I've got to do that then I might as well be living in a motel in town.
Originally, I had believed that I would of course use the wood stove for general daily heating but that has become unfeasible because although it is a micro-mini woodstove that I have built out of a 20 pound propane tank, it still goes through an incredible quantity of firewood during the long cold winter months.
So if am going to be running the light and the laptop from the LV-1012's AC output using 90 watts, then maybe I should get one or two 12v low wattage heaters to connect directly to one of the batteries in order to get them warmed up in the morning. I've got a 12v 3 socket car lighter plug adapter that I can plug into a second adapter which is a 12v lighter socket with short wires and two big alligator clips for clipping on to my battery terminals.
Then I could run one or two small 12v heaters for the batteries to keep warm and a low wattage 12v inverter to power the laptop and all directly from my batteries.
If anything that I have said so far sounds totally impractical then please let me know.
The area that I really need some help and advice on is the part where I need one or two more heaters to keep myself warm. Should they be the highest wattage 12v heaters that I can find? I mean, I guess I could hook-up half a dozen 12v heaters directly to the batteries.
Or should I be plugging the LV-1012's AC output into a 3 socket adapter so that I can plug in a couple of 120 volt space heaters?
And since the LV-1012 is a 1000 watt MPPT, then I guess I had better make sure that I never hook-up two 600w space heaters to it because it will get wrecked.
Thos
Thos
