tosimplify
- Nov 28, 2020
- 17
My SCC has a separate ground screw on the side, as does my 3000 watt inverter. I'm using a positive and a negative busbar to connect everything (batteries, SCC, inverter, loads...), and I'm wondering -- if I just run a wire from the negative bus bar to the chassis, would I then simply connect these SCC and inverter ground screws to my negative busbar? Seems redundant since both already are connected to both busbars.
