Hi All,
I have a question regarding grounding to the chassis. I looked through the available Resources here and couldn't find anything that related to my (unique?) situation.
Long story short. I am using one of the GFCI outlets on my camper to run a AC to DC charger for when I'm hooked up to shore power.
My question is, do I need to ground to the chassis at my negative buss bar? Or would that create a grounding loop since the Ac to DC charger, plugged in at the GFCI outlet is routed to the camper included converter/fuse/breaker box, which is grounded to the chassis at that point?
Below is a simplified version of my situation (I removed some aspects such as solar, SCC, ect) to simplify my setup to the relevant components.
Thanks for your help all.
