Yesterday I started up with the Google AI Bard. Still makes mistakes like Chat GPT. Today I read about inworld on New Atlas. After spending quite a lot of time inputting traits for the advisor avatar who is an expert on solar energy for the do it your selfer, the following conversation was not terribly efficient; still some mistakes:
Kitrobaskin: Hi. I am looking to build a solar powered system for my mid sized truck. The camper shell is 42 inches wide and 58 inches long but can overhang the truck cabin.
Sentora: (DOMINEERING) That's great to hear! We can definitely help you out with that. Let's start by discussing your power needs. How much power do you need to run your electronics and appliances? Also, what kind of battery capacity are you considering?
Kitrobaskin: The maximum watts I can put on the shell is 400 watts.
Sentora: (DOMINEERING) Great! With a maximum of 400 watts, we can design a system to meet your energy requirements. We'll want to consider factors like your daily energy usage, charging times, and any potential shading issues. Based on those factors, we can determine what size and type of solar panels, charge controller, and batteries you'll need. Don't worry, we'll make sure you have all the information you need to make an informed decision.
Kitrobaskin: I want to go with a 100 20 Victron charge controller, Victron 24V 1200 VA inverter, Epoch LFP battery but have not decided on solar panel(s).
Sentora: (DOMINEERING) Those are all excellent choices! For your panel , we'll want to find something with a high efficiency rating and the right physical dimensions to fit your truck's camper shell. Let's take a look at some options on the market and compare their features and pricing. Have you considered flexible or semi-flexible options? They could be a good fit for your application.
Kitrobaskin: I definitely want a rigid frame panel and am considering half cut cells or back cell circuit.
Sentora: (DOMINEERING) Those are both excellent options! Half cut cells can provide better efficiency and performance in low light conditions, while back contact cells can be more durable and have a longer lifespan. We'll want to take into account your specific needs and preferences, as well as your budget, to help you choose the best option for your setup.
Kitrobaskin: Can you suggest a panel that would be less than 43 inches wide and up to 72 inches long? I also would prefer a manufacturer that builds cells in USA or Mexico with the cells made in Philippines, United States or Vietnam but am open to other options.
Sentora: (DOMINEERING) Absolutely! One panel I recommend is the SunPower E-Flex series. It's 41.3 inches wide by 61.4 inches long, falls within your size requirements, and is manufactured in the USA with global parts. The company has a strong reputation for quality and reliability, with high-efficiency monocrystalline solar panels featuring half-cut cell technology. They also have a solid warranty policy. How does this sound?
Kitrobaskin: I only want a rigid frame panel. What about Silfab?
Sentora: (DOMINEERING) Ah, Silfab is another great option! Their SLA-M 320W-340W module is a rigid frame, and measures 41.5 x 78.7 x 1.57 in. It's made in North America, with cells from the US and Canada, and has a good efficiency rating. I think this could be a great fit for your setup.
Kitrobaskin: The panel must be no more than 72 inches long.
Sentora: (DOMINEERING) Fantastic! We can definitely find a rigid frame panel within those dimensions. There are many high-quality panels available on the market, and we'll make sure to select one with the right specifications for your system. With your power requirements and panel size in mind, I recommend considering either a monocrystalline or polycrystalline panel. Both types have their own advantages and disadvantages, so we'll want to discuss which one would be the most suitable for your project.
Kitrobaskin: Monocrystalline only.
Sentora: (DOMINEERING) Got it! I'm glad you have a preference. In my experience, the higher efficiency and longer lifespan of a quality mono-crystalline solar panel can make it an excellent choice for many setups. Let's take a closer look at some of the options on the market and find one with the perfect combination of performance, durability, and value for your specific needs.
Kitrobaskin: What do you think?
Sentora: (DOMINEERING) I think we're making great progress! Based on the information you've provided, we can design a high-quality, efficient system that meets your power requirements and fits within your budget. I'm excited to work with you and help you bring your vision to life!
Kitrobaskin: Can you suggest a specific solar panel?
Sentora: (DOMINEERING) Absolutely! One panel that comes to mind is the SunPower E-Series. It's a highly-efficient mono-crystalline panel that has a sleek, low-profile design and is built to withstand harsh weather conditions. It also comes with a 25-year warranty, so you'll have peace of mind knowing your investment is protected. Let me show you some more details on my laptop.
Kitrobaskin: Which model will fit on my truck shell?
Sentora: (DOMINEERING) Great question, Kitrobaskin! Based on the dimensions you provided earlier, I recommend the 400W model. It's 66.7 inches long and 40 inches wide, so it should fit perfectly on your camper shell. This model has an efficiency rating of up to 22.7%, meaning it can generate more power per square inch than most other panels on the market. It's made with high-quality materials and is designed to last for many years, even in extreme environments.
Kitrobaskin: Where can I buy it, given that I only want one panel and would like to purchase it in Albuquerque New Mexico?
Sentora: (DOMINEERING) You can check with local solar energy suppliers in Albuquerque to see if they carry the SunPower E-Series panel. If not, you can always order it online from a reputable supplier. I can provide you with some recommendations for online retailers that specialize in solar equipment if you'd like. You may also want to consider purchasing other components of your system from the same supplier to ensure compatibility and streamline the installation process.
Kitrobaskin: Yes please recommend.
Sentora: (DOMINEERING) Sure thing, Kitrobaskin! Some popular and reliable websites to purchase from include Wholesale Solar, Solar Electric Supply, and altE Store. They all have a wide selection of high-quality panels and other components, and they offer fast shipping to customers all over the country. Just make sure to double-check the dimensions of the specific model you choose to confirm it will fit on your truck shell.
